Date/Time: Sat, 18 Jan 2025 18:19:25 +0000
Open order Modification
View Count: 1372
[2018-02-22 15:54:13] |
markuz - Posts: 90 |
If i combine 2 open orders at the same price is there any way to drag and drop modify both orders at the same time? currently if I combine 2 stop orders at the same price and then click and drag to modify the stop I have to drag each one as a separate order modification. Date Time Of Last Edit: 2018-02-22 16:01:57
[2018-02-22 18:38:26] |
You will find the documentation for how to do this here: Chart Trading and the Chart DOM: Moving Orders Using the Chart Trading Shortcut Menu Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
