Date/Time: Sat, 18 Jan 2025 18:33:58 +0000
Can I have another trial?
View Count: 1224
[2018-02-22 15:14:33] |
bhetterick - Posts: 8 |
I previously had a trial a couple of years ago to try linking my TDAmeritrade account. At that time, I decided to just use the ThinkOrSwim charting package for my charting needs for equities. However, since that time I have been using point and figure charting in Sierra Chart with my Infinity Futures trading. I would like to see if the TDAmeritrade equity data would work well for point and figure charts in Sierra Chart. Is it possible to have another trial of Sierra Chart to try this out before I actually incur costs purchasing time on Sierra Chart? Many thanks.
[2018-02-22 15:38:50] |
Sierra Chart - Max - Posts: 5779 |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you can request another trial, up to a total of 30 days assuming you have not already received those trial days previously. After this you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support |
[2018-02-22 15:46:45] |
Got it. Many thanks....I very much appreciate your understanding and allowing me to try this feature out on Sierra Chart.
