Date/Time: Sat, 18 Jan 2025 13:05:49 +0000
trading system
View Count: 779
[2018-02-22 09:36:41] |
TheFibber - Posts: 83 |
i'm working to knowledge the trading system based on alert condition. i need some tricks: can i use stop orders there? and what kind of syntax i have to use can i use variables and constants ? remember i'm just using the TS based on alert condition |
[2018-02-22 09:54:59] |
Do you want to use a Stop for the entry order? You can certainly use a constant in the formula. Can you give us an example of what type of variable you would want to use? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-22 10:04:45] |
for stop order= example : IF CLOSE[-1] >high[-2] then buy stop order at High[-1] for variable: the low of every bar just passed through for a trailing stop (in hypothesis of a long trade) for constant: set the distance from the entry price to the low of the entry bar for example |
[2018-02-22 18:21:21] |
Really for all of this you will need to use the Spreadsheet System for Trading study: Spreadsheet Systems, Alerts and Automated Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-22 18:24:42
[2018-02-22 22:42:30] |
thanks but you didn't help me too much.
[2018-02-26 04:08:58] |
That is because your question is not within the scope of our support. Refer to: Automated Trading Management: Troubleshooting Automated Trading System Behavior Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
