Date/Time: Sat, 18 Jan 2025 18:24:40 +0000
Possible 1705 CTS FIX error
View Count: 1049
[2018-02-22 04:17:44] |
User35525 - Posts: 182 |
I just downloaded 1705 and cannot get historical data now: CTS T4 FIX | Server provided no historical order fills for account FFC3D4EB-72F9-4BB4-8FCF-70698DFD78DE | 2018-02-21 22:15:00 CTS FIX Historical Data: Unmatched MDReqID in received Market Data <W> message. Ignoring data. MDReqID: H2-0 | 2018-02-21 22:15:00 |
[2018-02-22 04:22:09] |
It's working now (about 10 minutes later). Was also seeing this: CTS FIX Historical Data socket (16) | Error setting send buffer size to 0. Unknown Windows error code 10022. | 2018-02-21 22:18:52 |
[2018-02-22 04:25:19] |
I take that back. There are problems now every time I disconnect/reconnect the data feed.
[2018-02-22 04:31:07] |
We are checking on this now.
[2018-02-22 04:42:03] |
Also post #2 is an operating system level error. We cannot help with that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-22 04:42:09
[2018-02-22 05:39:24] |
It will be about another few hours for us to get this release out as we want to do some additional code review. Could you please rollback to version 1697: Software Download: Software Rollback Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
