Date/Time: Sat, 18 Jan 2025 18:33:48 +0000
Ascill: Get all ticks of candle
View Count: 773
[2018-02-21 21:46:36] |
UserZiltoid - Posts: 57 |
Hello SC. Using the ASCILL interface I need to iterate over all the ticks of each candle. How can I do that? Thanks! |
[2018-02-22 04:23:31] |
You can use this function: sc.ReadIntradayFileRecordForBarIndexAndSubIndex() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
