Date/Time: Sat, 18 Jan 2025 13:12:37 +0000
how do I set rithmic data feed as default
View Count: 623
[2018-02-21 19:39:59] |
User651447 - Posts: 1 |
I have setup Sierra Chart with Rithmic as my data feed but whenever I open it it tries to connect to CQG's data feed? How do I set Rithmic as the default?
[2018-02-21 19:55:50] |
This is now solved for your Sierra Chart account.
