Date/Time: Sat, 18 Jan 2025 18:17:29 +0000
Unique SMS settings for buttons
View Count: 1313
[2018-02-21 15:35:05]
User644165 - Posts: 25
Hi All,
I am using custom buttons to draw normal horizontal lines and horizontal lines with sound alarm, but no SMS. Is there a way to add another button with sound alarm and SMS, while keeping the one with sound alarm but no SMS?
Thanks.
[2018-02-22 08:44:29]
Follow through the step-by-step instructions here:
Chart Drawing Tools: Configuring a Default Chart Drawing Alert Condition
[2018-02-22 14:22:02]
Hi There,
Thank you for coming back. I guess I was not clear.
So basically I want 3 different buttons.
1. no sound (done already)
2. sound alarm and SMS notificacion (done already)
3. sound alarm but no SMS -> how can I set this up?
[2018-02-22 18:27:00]
This is explained here:
For each default Alert Condition that you configure for a particular drawing tool and set a Control Bar button to use, use a different Alert Sound Number configured as you require:
General Settings Window: Configuring Alert Number Instructions
A particular Alert Number can be configured to use a SMS message.
Date Time Of Last Edit: 2018-02-22 18:28:00
[2018-02-22 19:50:53]
Sorry, I didn't recognise that the Alert Sound in the Drawing Alert config could also mean SMS and other actions, not just sound. Thank you for the help.
[2018-02-22 21:15:11]
Yes. It can be configured to perform multiple alert type actions.
