Date/Time: Sat, 18 Jan 2025 12:58:18 +0000
[Programming Help] - Reading error of overlay field into the Trading system based on alert condition
View Count: 868
[2018-02-21 15:23:27]
User657944 - Posts: 173
Sorry team but I found an issue that i did not have till this morning (5 days of testing till now) that is as follows:
I have a formula with some fields that are referred to the same chart and all this studies are working fine,then the only study that is an overlay from another chart is not recognized, but it was till 2 hours ago.
So the system is activating an order also if the condition is not true, I check it taking away each single study and all are recognized except this one that is Poc from a 60 min vol bar chart as per attached file, but again till 2 hours ago it was working fine.
Tested again now it's not a fixed error it's probably due to a non sync between the external chart data and the trading system data, because since is taking the data (as visible in the external data) changing the size the vlaue somtimes is changing sometimes not.
thx
Alberto
Date Time Of Last Edit: 2018-02-21 15:30:48
imagepoc60min.png / V - Attached On 2018-02-21 15:23:10 UTC - Size: 22.84 KB - 263 views
[2018-02-26 03:58:54]
This is not within the scope of our support at all:
Automated Trading Management: Troubleshooting Automated Trading System Behavior
