Date/Time: Sat, 18 Jan 2025 13:15:44 +0000
[Programming Help] - Unable to determine if custom studies file is 64 bit
View Count: 651
[2018-02-21 14:42:34] |
jsob - Posts: 39 |
SC Version: 1705 CPU: Intel i7-4770K, 3.50ghz, 16gig ram, Win 10 Pro Get this message when I "Build Custom Studies DLL". Error message does not appear when I select "Remote Build". Does the appearance of this error message indicate a problem or performance issue with the compiled file? Thank you |
[2018-02-21 16:54:18] |
Not sure why there is problem. You can safely disregard for now.
[2018-02-21 18:02:06] |
jsob - Posts: 39 |
fwiw, I do not get the message if I compile before loading a chart book. The issue only arises when I have charts open and, having modified my code, I re-compile my library. The newly modified studies run as expected and there are no problems that I am aware of. Thank you for your response.
[2018-02-21 19:19:20] |
Therefore, the explanation is the file is locked when it is being built during the check if it is a 64-bit DLL.
