Date/Time: Sat, 18 Jan 2025 13:21:29 +0000
Overlays
View Count: 637
[2018-02-21 13:42:14] |
User731023 - Posts: 138 |
Hi, Can I use (Overlay) Peaks and Valleys study from one chart to another. I want to put them on my trigger chart (Main chart). The reason I do not just do it directly on that chart is because I have it set to load only 5 days. The object is to keep the days down on that chart but have the Peaks/Valleys form another chart that has Volume by price study for the Peaks/Valleys that is set at considerably more days. Thanks as always |
[2018-02-21 19:14:17] |
It is not supported to overlay Peak and Valley lines from the Volume by Price study.
