Date/Time: Sat, 18 Jan 2025 18:33:48 +0000
connection error
View Count: 1011
[2018-02-21 13:38:59]
User778250 - Posts: 2
TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2018-02-21 07:37:28
TransAct Trading | Bridge process is not running! | 2018-02-21 07:37:30
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-02-21 07:37:30
DTC Client socket (103) | Creating socket. | 2018-02-21 07:37:30
DTC Client socket (103) | Connecting to IP: 127.0.0.1. | 2018-02-21 07:37:30
DTC Client socket (103) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-02-21 07:37:33 *
DTC Client socket (103) | Initiating close of socket by core. | 2018-02-21 07:37:33
DTC Client socket (103) | Closed. | 2018-02-21 07:37:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-21 07:37:33
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-21 07:37:33
TransAct Trading | Disconnected. | 2018-02-21 07:37:36
Will reconnect to the server in 110.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-21 07:37:36
Please help - have unistalled Norton and restarted several times - no luck!!!
[2018-02-21 16:51:16]
This is the information we have on this:
https://www.sierrachart.com/index.php?page=doc/TransAct.php#BridgeConnectionError
[2018-02-22 04:13:47]
User165139 - Posts: 1
TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2018-02-21 22:10:42
TransAct Trading | Bridge process is not running! | 2018-02-21 22:10:48
TransAct Trading | Connecting to the server 127.0.0.1. Port 12545 | 2018-02-21 22:10:48
DTC Client socket (142) | Creating socket. | 2018-02-21 22:10:48
DTC Client socket (142) | Connecting to IP: 127.0.0.1. | 2018-02-21 22:10:48
DTC Client socket (142) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-02-21 22:10:48 *
DTC Client socket (142) | Initiating close of socket by core. | 2018-02-21 22:10:48
DTC Client socket (142) | Closed. | 2018-02-21 22:10:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-02-21 22:10:48
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-21 22:10:48
TransAct Trading | Disconnected. | 2018-02-21 22:10:51
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-02-21 22:10:51
This is going on for about an hour now. I have not changed any of my pc settings!
Bridge icon appears on the taskbar and then disappears within a few seconds!
[2018-02-22 04:30:29]
You need to contact TransAct for help with this. This is not within our control.
