Date/Time: Sat, 18 Jan 2025 18:31:35 +0000
[User Discussion] - Rotate chart 90 degrees - Time on y-axis, price on x-axis
View Count: 1150
[2018-02-21 13:15:01]
User623552 - Posts: 69
Is it possible to effectively rotate the chart 90 degrees, so time is on the (vertical) y-axis, and price on the (horizontal) x-axis
I do not want to rotate my screen, so this is not a windows question
I specifically want to rotate a chart, so I can visualize the chart in a different way
[2018-02-22 02:41:58]
This is not supported.
