Date/Time: Sat, 18 Jan 2025 18:31:50 +0000
Volume Value Area Lines Study
View Count: 1129
[2018-02-21 10:57:40]
User942837 - Posts: 108
I am trying to add volume value area lines study to the studies of a Dom window however, the study is not coming up. Can you kindly explain why?
thank you
[2018-02-22 04:27:23]
We will make that study available for the Trading DOM as well.
However, since you want the Volume Value Area Lines, you can achieve this by adding the Volume by Price study and then changing the setting for Draw Mode to either Volume Profiles & POC, VAH, VAL, VWAP Lines or POC, VAH, VAL, VWAP Lines Only. See the documentation for this Input here:
Volume By Price Study: Draw Mode
If you really just want the VAH and VAL lines, then after setting the above Input to POC, VAH, VAL, VWAP Lines Only, go to the Subgraphs Tab on the VbP Study Settings page and set the POC and VWAP Subgraphs to Ignore. You can find documentation on changing the Subgraphs Draw Style here:
Chart Studies: Subgraphs Tab >> Draw Style
Date Time Of Last Edit: 2018-02-22 04:28:45
