Date/Time: Tue, 21 Jan 2025 10:37:56 +0000
daily chart replay
View Count: 1512
[2018-02-20 11:30:36] |
michelh - Posts: 159 |
Hi Sierra, My coder just finished my new cycles extractor. http://www.sierrachart.com/image.php?Image=1519126022565.png I am looking to use it for LONGER TERM strategies.... i.e. OPTIONS ON STOCKS. So i threw the new indicator on a daily chart of AAPL. I wanted to see how my new toy performs on a chart replay but it says I cant replay a daily chart? PLEASE PLEASE add replay for dailies. Thanks!!! M |
[2018-02-20 18:10:31] |
There is a way to do this indirectly. Refer to: Replaying Charts: Replaying Historical Daily and Higher Timeframe Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-16 00:52:18] |
User629461 - Posts: 184 |
Hi - Will you consider making use of daily data directly for replay? As intraday data doesn't always exist, or not enough intraday data available to makes this function useful. Thanks |
[2018-08-16 04:54:27] |
nicktrader - Posts: 730 |
It would also be helpful if you could set a correct time for the jump method (i.e. each 20:00h). At the moment I work with a the study "Color Bar Alert..." and this formula "=AND(BARTIME >= ((20*60+00)/(24*60)), BARTIME <= ((20*60+02)/(24*60)))" All alerts are visible in the alert manager and by double click the chart jumps. But I am not happy with that "quick&dirty" solution |
