Date/Time: Sun, 24 Nov 2024 05:31:41 +0000
Incorrect Trading Statistics After Update
View Count: 1452
[2013-09-27 15:04:12]
9baller - Posts: 38
Updated to version 1028 today...trade statistics are off by decimal point....$14.00 wins/losses showing up instead of $140.00....
[2013-09-27 16:27:23]
For what symbol? Is this on the Trade Activity Log? Or the Open Profit/Loss you see on the Trade DOM?
[2013-09-27 16:31:25]
9baller - Posts: 38
in the activity log only....symbol is novemeber crude...clx3 for cts
[2013-09-27 17:26:35]
To make sure you have the correct settings, select Global Settings >> Symbol Settings. Press the Update From Server button. Wait for the button to reenable and then press OK.
Go back to the Trade Activity Log and select Edit >> Refresh Log.
[2013-09-27 17:36:47]
9baller - Posts: 38
did what you suggested..did not take at first....closed down and restarted...now it's fine....thanks
