Date/Time: Sat, 18 Jan 2025 13:01:42 +0000
Add Aligned Renko to Fast Changing by Keyboard
View Count: 912
[2018-02-20 04:35:01]
JoseyWales - Posts: 67
I love using the Fast Changing by Keyboard feature of Sierra Chart. It is one of many conveniences that makes me prefer Sierra Chart as my charting platform. However, as of version 1697 their is no shortcut to change the chart to Aligned Renko.
If Flex Renko's shortcut is fr, maybe Aligned Renko can be ar.
I will also note that "Point and Figure Bar" and "Range Per Bar - New Bar on Range Met & Open=Close (int ticks)" also do not have shortcuts, however my request is specifically for Aligned Renko.
Changing Chart Bars Period
[2018-02-20 18:47:33]
Support for this actually does exist, but it is not properly implemented. We are correcting this now.
[2018-02-20 23:33:00]
I see these chart types now have associated shortcuts according to the documentation.
Thank you for the timely support, I look forward to using it in the next Sierra Chart version.
