Date/Time: Sun, 24 Nov 2024 05:25:40 +0000
Ask/Bid Volume Difference Bars
View Count: 2516
[2013-09-27 12:26:15] |
Kefir - Posts: 34 |
Hello, I would like to ask you a favor to help me setup "Ask/Bid Volume Difference Bars" study so that actual numbers would be displayed at each bar. I somehow can't find how to make the data visible. What I mean in detail is to see instead of a bar (red/green) actual numbers in a column... like 4 rows per bar where I would see AskV - BidV (that is close of the bar), Max AskV - BidV (that is high of the bar), Min AskV - BidV (that is low of the bar), Total Volume. Is it possible to see at least some of this data per bar? Thank you in advance Kind regards r.a. |
[2013-09-27 17:28:44] |
You need to use the Numbers Bars Calculated Values study. This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#NumericInformationBelowBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
