Date/Time: Sun, 24 Nov 2024 03:54:49 +0000
Create and scroll through list of stocks
View Count: 1616
[2013-09-27 06:27:12] |
user40663 - Posts: 54 |
Hi Is there a way to create a list of stocks (would you use quoteboard ??) eg s&p 500 stocks, and be able to scroll through the list of stocks and look at each chart? Thanks |
[2013-09-27 06:31:03] |
The Quote Board is a good method of doing this. It is documented here: http://www.sierrachart.com/index.php?l=doc/doc_GettingQuotes.html#QuoteBoard Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-27 06:31:13
[2013-09-27 06:36:11] |
Is there a way to import a list of stocks eg sp 500 or asx 200 etc etc instead of having to enter in each code?
[2013-09-27 17:07:05] |
You can import these from a plain text file. Refer to the documentation for this here: http://www.sierrachart.com/index.php?l=doc/doc_GettingQuotes.html#SavingLoadingImportSymbolList Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
