Date/Time: Sun, 24 Nov 2024 03:29:12 +0000
Lines move around relative to prices when adjusting scale
View Count: 1233
[2013-09-27 02:18:12] |
HamSandwich - Posts: 5 |
I use pitchforks frequently and need to rely on them not to move around and readjust relative to the prices but when I adjust scaling on my charts I notice that the pitchforks will readjust relative to prices. As you can imagine I need 100% accuracy with the scaling. How do I make sure that my pitchforks won't readjust themselves (even if slightly) when I play around with the scale?
[2013-09-27 04:37:28] |
Refer to the documentation here for the Pitchfork tool: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#Pitchfork It contains information on this subject in the Secondary Anchor Point section. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
