Date/Time: Sun, 24 Nov 2024 03:48:40 +0000
Invalid Chartbooks (cht) and Backups (cbak)
View Count: 1839
[2013-09-27 02:17:52]
User22396 - Posts: 191
from the other day i have 7 chartbooks as well as the respective backups that are now invalid..."The Chartbook file is not a valid Chartbook"
anything i can do to restore?
[2013-09-27 04:44:18]
If Sierra Chart says a Chartbook is not valid, then it is no longer valid for unknown reasons. Check among all of the available backup Chartbook files:
http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html#BackupChartbook
This is the only advice we can offer.
[2013-09-27 12:10:02]
yeah i already tried the backups...both the chartbooks and the backups say the same..."The Chartbook file is not a valid Chartbook"
[2013-09-27 16:26:20]
Attach one of the Chartbooks here which gives this error, following these instructions:
https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile
We will see what the problem is. You can make the file private so only we can see it.
