Date/Time: Sat, 18 Jan 2025 13:13:19 +0000
Windows 10 Installation
View Count: 964
[2018-02-17 20:53:29]
User931255 - Posts: 3
I signed up for the free trial, downloaded and have tried to install Sierra Chart 4 times now after rebooting, simply hangs
imagesierrainstall.PNG / V - Attached On 2018-02-17 20:52:25 UTC - Size: 23.79 KB - 357 views
[2018-02-17 23:14:23]
So the installer itself is freezing?
We have never heard of this before. If so, this is going to be an operating system level issue. Try disabling any security software you are running on your computer, during the installation.
[2018-02-17 23:41:45]
Disabled Norton Antivirus, installer still hangs. I've attached the log file
Private File
[2018-02-18 00:04:08]
I finally got the software installed, thanks 😉
