Date/Time: Sat, 18 Jan 2025 13:07:06 +0000
256 simple alerts
View Count: 956
[2018-02-17 20:24:23]
User35525 - Posts: 182
Is it possible to increase the max number of simple alerts from 256 to 512?
It will help with people using simple alerts, which is what I'm using since I can't get Spreadsheet studies to work in Wine.
Date Time Of Last Edit: 2018-02-17 20:25:26
[2018-02-17 23:17:58]
Do you mean the number of characters in a Simple Alert Formula? Yes, we do plan to work on that. We will get it done soon.
The plan is to remove the limit altogether.
[2018-02-18 04:57:53]
Thank you! I meant the max number of alerts/studies allowed on a chart, but removing the max length for a Simple Alert Formula would be a huge help and also give breathing room (could then fold many alerts together into lengthier alerts).
Nobody thought they'd ever need more than 640KB RAM, until they did. :-)
[2018-02-18 06:09:57]
Yes we can increase the limit.
Also this is very surprising. We would not expect this at all. Anyway, if this is the case for you, then probably not much we can do with it at the moment.
Date Time Of Last Edit: 2018-02-18 06:10:20
