Date/Time: Sat, 18 Jan 2025 11:06:18 +0000
Delete all data and download:
View Count: 1266
[2018-02-17 17:48:49] |
i960 - Posts: 360 |
In the window to select which contracts to delete and redownload the "select all" and "deselect all" buttons don't do anything. If you click on them the selection remains the same.
2018-02-17 09_47_16-Multiple Symbol Selection Window.png / V - Attached On 2018-02-17 17:48:00 UTC - Size: 6.98 KB - 262 views |
[2018-02-17 23:13:07] |
We will look into this.
