Date/Time: Sat, 18 Jan 2025 10:48:50 +0000
Simple Cloud based way to move my current Chart books and settings to new computer
View Count: 1599
[2018-02-17 05:04:44] |
User180814 - Posts: 45 |
Hello Sierra Chart Support, Is there a simplistic way to move my current layout of charts and settings from my lap top over to a new computer. I have seen some complicated ways of doing this posted, but I am looking for a cloud way of doing it. Download it to the cloud and just pull it up on a new computer. Is this possible? If not what is the easiest way available to accomplish this for the computer incompetent. Thanks Sierra Charts. |
[2018-02-17 23:19:20] |
Since Sierra Chart is a portable program, it is one of the most easiest desktop programs to move or copy from one system to another. Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Simple Transfer/Copy of Sierra Chart Installation to Another Folder or Computer System One of the easiest ways to do this without involving the Internet is to use a USB flash drive: https://en.wikipedia.org/wiki/USB_flash_drive Instructions: -Insert a USB flash drive into the computer you are copying Sierra Chart from. -Copy Sierra Chart to this flash drive. -Remove the flash drive from the computer that you are copying Sierra Chart from. Insert the USB flash drive into the computer you are copying Sierra Chart to. - Copy the Sierra Chart folder on tthe flash drive into the location you want to on the destination computer. Also this file sharing feature may be useful: File Sharing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-17 23:23:23
[2018-02-17 23:22:23] |
Prior post updated.
