Date/Time: Sat, 18 Jan 2025 10:45:55 +0000
Enter Text box keeps coming up when I click on the screen
View Count: 628
[2018-02-16 21:22:49]
User558533 - Posts: 1
When I click anywhere on the screen an Enter Text box pops up. When I click ok it goes away but it is interferring with my trading. I can't get rid of this annoyance. It never use to do this.
[2018-02-16 21:43:02]
John - SC Support - Posts: 37327
You have the Type Text or Stationary Text Drawing tool selected in your Tools pulldown menu. Select a different tool, or select Pointer to not have any drawing occurring when you left-click your pointer. The documentation for selecting a drawing tool can be found here:
Chart Drawing Tools: Selecting Drawing Tools
In addition, be sure to check the setting for After Single Tool Use Change To: setting on the Global Settings >> Tool Settings page. Be sure this is set to the value you want. You can find the documentation on this setting here:
Chart Drawing Tools: Using a Tool One Time, and Switching to the Default Tool
Date Time Of Last Edit: 2018-02-16 21:48:25
