Date/Time: Sat, 18 Jan 2025 13:06:25 +0000
[Programming Help] - spreadsheet trading question
View Count: 1894
[2018-02-16 20:58:06]
Glenn Infinity - Posts: 103
Is it possible to generate a "Buy Entry"/"Sell Entry" on a specific price as defined by cell K3/M3?
For example I'm interested in entering on the price 5 ticks below the Moving Average Cross.
[2018-02-17 00:21:32]
Sawtooth - Posts: 4154
To place Limit entries 5 ticks below/above Close price at the signal of a MA crossover in K3 or M3, try this:
1. Find the MA crossover in K3 and M3, and use it for the entry signals:
=CROSSFROMBELOW(ID1.SG1@3:ID1.SG1@4,ID2.SG1@3:ID2.SG1@4)
=CROSSFROMABOVE(ID1.SG1@3:ID1.SG1@4,ID2.SG1@3:ID2.SG1@4)
where the ID#s of the MAs are ID1 and ID2, and ID1 is the faster MA; edit as needed.
2. Return the Close price of the faster MA at the crossover:
-Put this in J22:
=IF(K3,ID1.SG1@4-5*J21,0)
Put this in J24:
=IF(M3,ID1.SG1@4+5*J21,0)
-Set J71 and J73 to L
[2018-02-18 13:51:53]
User241198 - Posts: 6
This is the condition I'm interested in.
Is it possible to send an order to the market that is a "Stop-Fill?"
For example, where a Limit-Buy-Stop order is sent 5 ticks above the current price OR a Limit-Sell-Stop order is sent 5 ticks below the current price.
If the market reverses and moves away from that limit order, is it possible to cancel that with an Exit Buy/Sell condition?
[2018-02-18 14:19:13]
The entry orders in that case would be called a Buy Stop or Sell Stop.
Use this instead:
-Put this in J22:
=IF(K3,ID1.SG1@4+5*J21,0)
Put this in J24:
=IF(M3,ID1.SG1@4-5*J21,0)
-Set J71 and J73 to S
[2018-02-20 13:43:38]
the column "J" rows he referenced are not on the TA spreadsheet, J22, J24, J71 and J73.
What do I need to do to get those cells functioning?
[2018-02-20 13:50:22]
Those cells are only used in the Spreadsheet System for Trading study.
[2018-02-20 14:33:56]
thank you!
[2018-02-21 18:51:59]
Here's my issue, In a Spreadsheet in Cells J63 & J64 I am unable to Save a "True" (1) value in those cells. I can make the change in the spreadsheet and then do a "Ctrl-S" but when I exit and return or I run a back test the values change to "False" (0) and my backtest fails.
[2018-02-21 20:43:51]
Those are read only output values from the spreadsheet study settings and cannot be edited on the spreadsheet sheet.
Set those values in the spreadsheet study settings.
