Date/Time: Sat, 26 Apr 2025 09:39:09 +0000
[Programming Help] - Alert: Error: #SYNTAX!
View Count: 1097
[2018-02-16 20:07:39]
User413206 - Posts: 36
I am attempting to create an alert using the "Color Background Based on Alert Condition" with intent to use the condition in the "Trading System Based on Alert Condition."
I am using the swing points study and price in the alert.
The swing points study I am using is located here:
Fractals indicator
I want to generate an alert, when the price crosses the Swing Low from above (i.e., price breaks the previous Swing Low to the downside).
I am using the following formula:
CROSSFROMABOVE(C, ID1.SG2)
It isn't working. I am seeing Error: #SYNTAX!
Does the logic need to be coded in C++? I hope not, because I don't remember much C++ from the only class I had.
Thank you.
Date Time Of Last Edit: 2018-02-16 21:11:25
[2018-02-16 22:04:33]
This is a perfectly valid formula:
Make sure it is just this.
