Date/Time: Sat, 18 Jan 2025 11:03:39 +0000
Volume by Price - Increment 'Tick per Volume Bar' hotkey
View Count: 1067
[2018-02-16 17:26:13]
knoxville1915 - Posts: 38
In the Volume by Price study, is there a way to increment up/down the value for the 'Tick per volume Bar' field? I find myself adjusting this field quite often as I move between securities that trade at considerably different price levels.
Alternatively, if you can direct me to the study file that has this code, I could assign a custom acs hotkey.
Many thanks
[2018-02-16 18:02:26]
No there is not. You just need to use Study Collections to switch between different saved configurations:
Study Collections
Date Time Of Last Edit: 2018-02-16 18:02:56
