Date/Time: Sat, 18 Jan 2025 10:48:53 +0000
2 charts, smae timeframe out of drawing differently
View Count: 578
[2018-02-16 17:24:59]
Devil_On_WallStreet - Posts: 67
I'm using 2 flex renko charts 6-3-0... 1 is a regular "renko bar with wicks" and the 2nd has numbers bars on it. I've been noticing for some time that the regular one doesn't seem to be plotting reversal bars properly... the one with numbers bars attached is... I mean they are plotting correct time and price levels, just when it comes to reversal bars, they get out of sync.. for every 1 reversal bar on the numers bars chart, there is 2 on the regular... any help on this???
[2018-02-16 18:09:02]
Make sure the Chart >> Chart Settings are completely identical between these charts.
You will also want to use the Renko Bar New Bar Modes which support Numbers Bars:
Renko Bar Charts: Renko New Bar Mode
Also refer to:
Renko Bar Charts: Using Numbers Bars Study on Renko Charts
Date Time Of Last Edit: 2018-02-16 18:10:12
