Date/Time: Sat, 18 Jan 2025 10:50:27 +0000
passing SCStudyInterfaceRef to another function
View Count: 852
[2018-02-16 16:18:26] |
traderacademie - Posts: 38 |
Hi, I'm starting to program in ACSIL and don't want to do everything inside 1 function (SCSFExport scsf_UniqueFunctionName(SCStudyInterfaceRef sc)) so I am wondering how or if it is possible to use the SCStudyInterfaceRef reference inside another function? I've tried passing it as a function parameter, but this doesn't seem to work rgds |
[2018-02-16 18:18:55] |
Refer to: ACSIL Programming Concepts: Passing ACSIL Interface Members Structure To Secondary Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
