Date/Time: Sat, 18 Jan 2025 11:09:28 +0000
[Locked] - Auto Retracement/Projection hide all but current levels?
View Count: 746
[2018-02-16 15:50:55] |
sjk - Posts: 43 |
The chart is too busy with all the levels shown. How do I hide all but the current levels? Thank you
[2018-02-16 18:10:57] |
You can either set the percentage for the level to 0 on the Inputs, or change the draw style to Ignore or Hidden for the particular subgraphs related to the levels you want to hide. For information on the Draw Styles for the subgraphs, refer to this section: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-16 18:24:20] |
sjk - Posts: 43 |
I want all CURRENT levels not historic ones.
[2018-02-16 18:47:33] |
Use the Number of Days to Calculate Input with this study.
[2018-02-16 18:53:20] |
sjk - Posts: 43 |
these are for renko charts not "days". One intra day
[2018-02-16 19:38:40] |
That Input still applies. Just set it to 1. In any case we cannot provide any further help if it does not meet your requirements for whatever reason. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-16 21:53:28
[2018-02-16 21:57:57] |
You need to set Number of Days to Calculate to 1. Refer to the documentation: Auto Retracement/Projection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-16 22:03:00
