Date/Time: Sat, 18 Jan 2025 11:05:58 +0000
different VWAPs on different period settings
View Count: 623
[2018-02-16 09:36:56] |
User884550 - Posts: 149 |
please advise how to make vwaps calulated correctly on different time frames, shall i use volume or time charts? I have a intraday chart 8 renko for DAX, and another long term 5000 volume chart, both have monthly vwap indicators on them, but both show very different vwaps, and it seems to me that renko is incorrect |
[2018-02-16 17:36:50] |
The first thing we want you to do is to update to the latest prerelease: Software Download: Fast Update And then you will want to set the Input Base on Underlying Data to Yes : Volume Weighted Average Price (VWAP) with Standard Deviation Lines: Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
