Date/Time: Sat, 18 Jan 2025 13:15:58 +0000
a simple Indicator development
View Count: 1774
[2018-02-16 07:52:34] |
Sierra2017 - Posts: 8 |
Hello Sierra Chart, I was wondering if you provide programming service on a simple indicator programming? I need a free Tradingview indicator being converted for Sierra chart. Thanks |
[2018-02-16 08:46:41] |
Yes we might be able to do that. Could you provide us the indicator formula so we can have a look.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-16 08:46:52
[2018-02-16 15:29:01] |
Thank you. Here you go! study("MACD Leader [LazyBear]", shorttitle="MACDL_LB") src=close shortLength = input(12, title="Fast Length") longLength = input(26, title="Slow Length") sigLength = input(9, title="Signal Length") showMACD=input(false) showMACDSignal=input(false) ma(s,l) => ema(s,l) sema = ma( src, shortLength ) lema = ma( src, longLength ) i1 = sema + ma( src - sema, shortLength ) i2 = lema + ma( src - lema, longLength ) macdl = i1 - i2 macd=sema-lema hline(0) plot( macdl, title="MACDLeader", color=maroon, linewidth=2) plot(showMACD?macd:na, title="MACD", color=green) plot(showMACDSignal?sma(macd, sigLength):na, title="Signal", color=red) |
[2018-02-16 22:06:29] |
Do you know what this means: ma(s,l) => ema(s,l) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-16 23:16:04] |
SC Support Tom - Posts: 450 |
I have located the documentation that answers this question: Do you know what this means: ma(s,l) => ema(s,l) This is a function declaration. It assigns the value of the built-in function "ema" (Exponential Moving Average) to the user-defined function "ma". Documentation: https://www.tradingview.com/wiki/Declaring_Functions |
[2018-02-20 18:17:08] |
This study is now available in "Prerelease" 1705. Follow the instructions here to update: Software Download: Fast Update It is called MACD Leader. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-20 18:17:15
[2018-02-20 18:52:56] |
Great :) Thank you
