Date/Time: Sat, 18 Jan 2025 13:15:00 +0000
[Programming Help] - Swing Hi Lo not emiting alert signals
View Count: 1458
[2018-02-16 06:47:27]
User360283 - Posts: 506
I have alert code "=or(sg1<>0,sg2<>0)" No errors
No signla is generated
Help please
[2018-02-16 07:23:38]
Your formula needs to reference prior bars because the signals from this study do not exist on the last bar.
Reference:
Study/Chart Alerts And Scanning: Referencing Data Other Than on the Last Bar/Column In the Chart
Date Time Of Last Edit: 2018-02-16 07:24:07
[2018-02-17 16:43:52]
Still not emitting
Alert code is now : =or(sg1[-1]<>0,sg2[-1]<>0)
[2018-02-18 01:04:27]
Based on the study data is that formula logical and would it work? Only you can determine that.
[2018-02-18 02:58:02]
Sawtooth - Posts: 4154
=OR(SG1[-5]<>0,SG2[-5]<>0)
The negative bracketed value needs to match the positive Length setting in the Swing High and Low study.
The above formula works for a Length of 5.
Keep in mind that this study 'repaints' so you won't get an alert until the arrow appears which in this example is 5 bars later.
Date Time Of Last Edit: 2018-02-18 14:13:01
[2018-02-18 09:55:02]
thanks Tom. Do you have any new stuff? what is you web site?
[2018-02-18 14:13:23]
sawtoothtrade.com
