Date/Time: Sat, 18 Jan 2025 13:17:57 +0000
tpo/vol profile causing serious system lag
View Count: 916
[2018-02-16 04:26:58] |
User342238 - Posts: 44 |
Hi, I have a tpo/volume profile chart up, just one chart, nothing else running. It's a weekly chart with four weeks of data loaded, and it is causing my system to run very slowly... Is this normal? |
[2018-02-16 04:31:27] |
No, that is not normal and there are solutions to this. So we can have a better understanding of this, provide an image of the TPO chart, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-21 08:46:48
[2018-02-21 08:44:31] |
Let us know if you still need help with this.
