Date/Time: Sat, 18 Jan 2025 11:04:32 +0000
DailyProfitLoss
View Count: 708
[2018-02-15 14:04:29] |
User39772 - Posts: 311 |
DailyProfitLoss of s_SCPositionData is always 0, I assume that this variable should hold the accumulated loss of a each single trading day and is reset every day to 0. Instructions on Automated Trading From an Advanced Custom Study are maintained. Please help. Questions: 1. Meaning of CumulativeProfitLoss is not 100% clear, does it cumulate all results or only consecutive loosers or consecutive winners. 2. Scaling out of a position, ist there an example code for implementing the scaling out of a position in c++ available or could you make it available ? 3. Is it possible to add data to the TradeActivityLog, i.e. to add further colums and add statistics from the trades that occur ? Thank you. |
[2018-02-15 19:14:34] |
Here is the documentation for Daily Profit/Loss: Help With Daily Profit/Loss Value 1. It does the calculation using all of the order fills. 2. No we do not have this. 3. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-15 19:14:44
