Date/Time: Sat, 18 Jan 2025 13:22:39 +0000
[User Discussion] - market depth and background alert ?
View Count: 1429
[2018-02-15 13:06:29]
zippyzip - Posts: 293
hi is there setting to make the background alert come through when market depth is being used ? i have tried to change advanced settings draw options in chart settings with no luck . thanks
Private File
[2018-02-16 18:28:16]
Adam - Posts: 141
Same problem here
[2018-02-16 18:33:43]
User226429 - Posts: 4
If there were a way to accomplish this, that'd be great.
[2018-02-16 18:46:57]
User132748 - Posts: 159
yea thats quite annoying pls make this work. thanks
[2018-02-18 16:33:04]
nevermind i figured it out , have to use color bar alert and use transparent fill rectangle , thanks for the help
Date Time Of Last Edit: 2018-02-18 16:33:28
image2018-02-18_11-30.jpg / V - Attached On 2018-02-18 16:33:25 UTC - Size: 83.36 KB - 372 views
