Date/Time: Sun, 24 Nov 2024 03:51:40 +0000
Alert Sound on new Heiken Aishi bar
View Count: 1269
[2013-09-26 22:50:36] |
Marco Gundel1 - Posts: 18 |
Hi Sierra Team, I am looking for a possibility to have a sound alert once a new Heiken Aishi Bar starts to print. The Heiken Aishi is based on a 3 tick renko bar. Can you please help? Thanks so much in advance Marco |
[2013-09-27 04:59:44] |
The most simplest way of doing this is to use the Countdown Timer study and set it to alert on a new bar: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s201 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
