Date/Time: Sat, 18 Jan 2025 10:58:30 +0000
improving performance
View Count: 1276
[2018-02-14 23:23:04] |
User968625 - Posts: 260 |
I have noticed a big drop in the SC performance recently. As I moved away from TradeStation to SC I started encountering problems and many of these are caused by issues you refer to in the help section - too many open charts (too many visible), drawings, --etc. I am wondering if I add a second instance (and maybe even a third) if that should improve the performance. I am always monitoring the performance of my CPU and memory and the system is doing well (it is a capable machine). I have a second copy from when I was trying AMP so I can remove this copy (as it is old with AMP setting and IQ deta feed) and install a new one If I do that, will I have to pay extra fees for SC data feed? I no longer use IQ data and now use SC. I use IB TWS but I plan to trade on only one instance. Date Time Of Last Edit: 2018-02-14 23:33:24
[2018-02-15 03:35:14] |
I am wondering if I add a second instance (and maybe even a third) if that should improve the performance. Yes but just also make sure you have a CPU with at least four cores and preferably more, and that you use solid-state drives and have one just dedicated for Sierra Chart.Here are instructions to use additional copies of Sierra Chart: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-15 10:47:35] |
I don’t have a hard drive dedicated to Sierra charts. I will try to add one - I have 8 cores. - If I add another PC or laptop then it is an extra connection for 20? - and also, as I am moving all my trading here I was thinking to get a dedicated VPS (like speedy trading VPS). I can still have two or three instances here with my market data and another one that works as a server for all orders with he extra 20 for the server, right? Date Time Of Last Edit: 2018-02-15 11:15:55
[2018-02-15 18:38:46] |
Use a solid-state drive and not a hard drive. And you should have one dedicated just for Sierra Chart. - If I add another PC or laptop then it is an extra connection for 20? I can still have two or three instances here with my market data and another one that works as a server for all orders with he extra 20 for the server, right? Yes this will work.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-15 18:39:05
