Date/Time: Sat, 18 Jan 2025 10:08:45 +0000
Text Size Fibonacci Retracement
View Count: 1493
[2018-02-13 08:13:47]
User371906 - Posts: 141
Is it possible to change the text size in Fibonacci Retracement so that they percentage numbers (23.6%, 50%, 61,8%) appear smaller on chart?
I tried in Chart- Graphics Settings Chart options but can seem to make them smaller.
Please let me know
Thanks in advance
g
[2018-02-13 18:03:03]
The text on the Fibonacci Fan is controlled through the Font selection for Chart Text. So it can be changed, but this will also change all the other text in the chart, including the scales.
To change this setting, refer to the following documentation:
Graphics Settings: Fonts and Text Appearance
Most likely you were trying to change this on the Chart >> Graphics Settings - Chart while the option Use Global Graphics Settings Instead of These Settings was enabled. For information on this setting, refer to this documentation:
Graphics Settings: Use Global Graphics Settings Instead of These Settings
Also refer to:
Chart Drawing Tools: Changing the Font Size For Text Displayed with Tool Drawings (Global Chart Drawing Font)
Date Time Of Last Edit: 2018-02-13 18:18:32
