Date/Time: Sat, 18 Jan 2025 13:04:31 +0000
compact value window
View Count: 827
[2018-02-13 00:19:36] |
User163689 - Posts: 29 |
when you pick blank for graph draw type where can you change the colors for the compact value window? no studies are selected but it shows various colors in compact value window for open/high/low etc . I would like them all to be white. If i put candlestick they all show up white and would like that for blank also. If i missed something excuse me but I've been looking for days This is a new chart with nothing but a symbol in this case F.US.EPH18
Date Time Of Last Edit: 2018-02-13 00:21:07
[2018-02-13 21:51:09] |
We need to look into this.
[2018-02-23 16:34:04] |
any thoughts?
[2018-02-23 18:10:31] |
This has now been resolved. Update to the current version following these instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
