Date/Time: Sat, 18 Jan 2025 11:10:58 +0000
[Programming Help] - increase number of SC_SUBGRAPHS_AVAILABLE for custom study
View Count: 883
[2018-02-12 20:19:22]
User494732 - Posts: 7
Hi I developed study for displaying multiple horizontal lines based on the content for text file , however number of lines limited by SC_SUBGRAPHS_AVAILABLE constants.
Is it possible to change this constant manually for developing a single custom study , than top reverse it back to standard after producing DLLs ? Please advise
This is from scconstants.h
const int SC_SUBGRAPHS_AVAILABLE = 60;
const int SC_INPUTS_AVAILABLE = 128;
const int SC_DRAWING_MAX_LEVELS_OLD = 32;
const int SC_DRAWING_MAX_LEVELS = 64; // Do not change this, used in s_ChartDrawing and s_ConfigData
const int ACSIL_DRAWING_MAX_LEVELS = 32;
const int NUM_LINREG_TOOL_STD_DEVIATIONS = 12;
[2018-02-12 23:12:14]
No, that is not possible. You just have to use multiple study instances to overcome the limit.
[2018-02-13 01:56:20]
Please advise
1. how to make input data file available for custom study through configuration/setting of the study
2. how to make study to update the data from the file without removing/adding study to the chart
[2018-02-13 21:49:46]
1. It sounds like you would want to use a text string input:
ACSIL Interface Members - sc.Input Array: sc.Input[].SetString()
2. This is something for you to implement. You can do whatever you need within the study function. It is not something we can help with. If you want the study function continuously called, then you can use this variable:
ACSIL Interface Members - Variables and Arrays: sc.UpdateAlways
Date Time Of Last Edit: 2018-02-13 21:50:49
