Date/Time: Mon, 25 Nov 2024 10:31:13 +0000
Clock On Top
View Count: 1168
[2018-02-12 19:51:34]
User104854 - Posts: 456
I'm using the clock - real time study and have the clock on my chart. I would like it to always be on top of everything on the chart. Drawings, studies, main graph, everything. I cannot seem to get it to always be on top and I used to be able to. I've tried every setting on the chart-advanced tab and I've also made sure that the study is at the bottom of my studies list. Having other studies always on top seems to work fine but not with the clock for some reason.
Can you help please?
[2018-02-13 04:10:38]
In the next release there will be a new Input setting with this study to allow the study to be drawn above the main price graph or not. This will give you the most maximum control along with what is documented here:
Chart Studies: Study Display Order
[2024-03-07 23:20:57]
cesium - Posts: 85
Hello, Currently im using this same study, and the Market Depth historical graph will cover up the clock.
Im using Draw study underneath price graph is **unchecked**, and I have this study in last place in my studies list
Is there a setting somewhere that I am missing?
Thank you
Date Time Of Last Edit: 2024-03-07 23:21:05
[2024-03-08 14:39:38]
Make sure the Input for "Draw Above Main Price Graph" is set to "Yes". Refer to the following:
