Date/Time: Mon, 20 Jan 2025 11:23:36 +0000
Compact Tool Values Window
View Count: 727
[2018-02-12 17:17:53]
User536593 - Posts: 11
upgraded to version 1697 and now my compact tools window will not open
[2018-02-12 18:21:13]
Refer to this section here about this:
Chart Drawing Tools: Cannot See Values Windows? (Cannot See Values Windows?)
Date Time Of Last Edit: 2018-02-12 18:21:38
[2018-06-13 14:31:53]
it shows the vertical line in wrong place after I click to add
Private File
[2018-06-14 03:44:37]
This response is posted in the wrong thread. But anyway, the problem is you are using an unsupported study. Do not use the Renko studies and instead follow the instructions here:
http://www.sierrachart.com/index.php?page=doc/RenkoCharts.html
