Date/Time: Wed, 23 Sep 2026 17:29:36 +0000
Cant turn off daily P/L in trade window
View Count: 1715
| [2013-04-05 09:48:44] |
| Zonescalper - Posts: 6 |
Dear support, I tried to turn off the Daily P/L in the trade window by disabling Display daily profit/loss on chart/on DOM, but I still get to see the daily result in the trade window. I only want to see the current P/L of the position I am trading. When I turn off position profit/loss in chart settings I also turn off the current P/L. How can I turn off the daily P/L in the trade window, but still have the open P/L running? Kind regards, Zonescalper |
| [2015-09-03 07:45:20] |
| Jagui - Posts: 19 Invalid SC Account Name. |
Me too. Cannot get rid of the DPL on the chart trade window attached to the chart, even if the option CHART TRADE SETTINGS => DISPLAY DAILY PL IN CHART/TRADE WINDOW is turned off.
Date Time Of Last Edit: 2015-09-03 07:45:42
| [2015-09-03 09:49:54] |
| NumbersBars - Posts: 141 |
Yes, I am having the same question. Would like to know how to turn off DailyPL on Trade Window.
| [2015-09-03 09:58:13] |
It is possible to set all of the Profit/Loss values to 0 on the Trade Window but not just the Daily Profit/Loss.
| [2021-03-24 17:48:14] |
| User8135477 - Posts: 135 |
Dear Support, I would also like to have the option to switch off just the Daily PF on trade window, but keep the current P/L. Could you kindly consider adding the function to the next update for Sierra Chart. |
