Date/Time: Sat, 18 Jan 2025 10:04:08 +0000
trading system examples to download and some others..
View Count: 860
[2018-02-12 09:21:53] |
TheFibber - Posts: 83 |
could you suggest me some sample to download from somewhere of a trading system built by some one who wants to share ?(perhaps of no value but doesn't matter. it's not this tipe of inquiry)i need to study the code to understand how to make one by my own. i need to put in formula my ideas to back test it. it's a very hard task for me so could you help me also with the step i need to follow to learn : how to project a trading system how to back test it how to run in real time with a sample to download precompiled would be much faster to acknowledge all the matter. thanks |
[2018-02-12 18:04:43] |
We think it would be best that you start off using the Spreadsheet System for Trading study. It is fully documented here: Spreadsheet Systems, Alerts and Automated Trading Or you could use this new study: Trading System Based on Alert Condition These are very easy to get started with and will allow you to create a trading system based on simple formulas. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-02-12 18:36:31
