Date/Time: Sat, 18 Jan 2025 10:08:33 +0000
Can't open replay function
View Count: 1101
[2018-02-12 05:11:45] |
User172040 - Posts: 70 |
On Saturday I started to work with the replay function and it worked fine. However, yesterday and today, when I click Chart -> Replay Chart (or do Ctrl R) then nothing happens. The replay window does not appear. I've also reset the Child Windows but still no replay window that pops up. Can you please guide me. I've already gone through the Replay documentation but there was nothing that helped. The only recommendation in the documentation is to Reset the Child Windows, which, as I mentioned, did not work
[2018-02-12 06:00:13] |
That is not exactly what the documentation says. Refer to: Replaying Charts: Chart Replay Window Not Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
