Date/Time: Sat, 18 Jan 2025 09:56:07 +0000
Range bar
View Count: 1034
[2018-02-11 22:48:30] |
User117845 - Posts: 2 |
Hi, I’m using Interactive Brokers, trading my Hong Kong future market but they don’t have range bar indicator Is possible that i use Sierra Chart link up the IB real Time data and using the range bar indicator together ? |
[2018-02-11 23:23:44] |
Yes this is fully supported.
[2018-02-12 05:29:58] |
How? Is any setup video ?
[2018-02-12 06:03:08] |
There is not a video . If you want to connect to Interactive Brokers , there are step-by-step instructions here: Interactive Brokers Trading Service: Setup Instructions Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
