Date/Time: Sat, 18 Jan 2025 10:16:21 +0000
[User Discussion] - intraday data compression
View Count: 929
[2018-02-11 21:19:52]
anouar6869 - Posts: 13
Is it possible to have in the Intraday Data file management the option to choose a custom unit size compression?
The reason is that I use custom timeframe and a custom value would perfectly reduce the files size with no loss in accuracy.
Alternatively there are other way to do that?
[2018-02-12 18:28:00]
The option you are looking for is the Compress to Data Unit Size on Global Settings>> Data/Trade Service Settings>> Data File Management window. You can find the documentation for this here:
Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings)
It cannot be customized though beyond the existing settings.
Date Time Of Last Edit: 2018-02-12 18:30:01
