Date/Time: Sat, 18 Jan 2025 09:57:27 +0000
[Programming Help] - VWAP behaviour during replay
View Count: 739
[2018-02-11 19:08:12]
bala - Posts: 74
Here is the situation.
1.Creating VWAP and std bands on a 1 tick chart . Creating signals based on standard deviations.
2. I check the chart for standard deviations.
2. I run a auto replay and back test. The standard deviation results are totally different.
3. The standard deviations computed and displayed after the auto replay ( both bar based replay and standard replay) are VASTLY DIFFERENT from standard deviations computed on a chart by a study before the replay!
(example: Before a test from the chart I should get 6 signals. Because the autoreplay produces different std values it produces 17 signals.).
I don't know if I can trust the chart or the backtest!
Is this normal? can VWAP be used on tick charts?
Private File
[2018-02-12 18:10:18]
What is the exact name of the VWAP study you see listed in Analysis >> Studies that you are using?
We ran a test and we do not observe any problem like this. Maybe it is not a Sierra Chart provided study.
Date Time Of Last Edit: 2018-02-12 18:10:29
[2018-02-13 17:30:35]
bala - Posts: 74
It is a custom study where moving averages intersect SD bands - very simple. The SD lines crossovers by price. The study is fine (including the SD values ) as are the indicators. The problem occurs when I run the replay. The SD bands during replay are entirely different.
If you don't encounter the problem its ok!!
